I have an Egardia alarm system which can be activated by Home Assistant. I also have a motion sensor and a door sensor from Xiaomi which can activated for example lamps. Is there a way I can trigger the Egardia alarm by those Xiaomi sensors? The are trigger codes from the Egardia system as explained by https://www.home-assistant.io/components/egardia/ but I can’t relate them in HA to trigger the alarm.
