Here’s what I came up with -
[{"id":"cecbb60b.5c47c8","type":"comment","z":"1663a5e8.75665a","name":"state trigger for when bulb goes from off to on","info":"","x":590,"y":280,"wires":[]},{"id":"df9b365e.cd57b8","type":"trigger-state","z":"1663a5e8.75665a","name":"bulb_bagnetto off -> on","server":"26956a45.92d866","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"light.bulb_bagnetto","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"id":"78a7i05h2pt","targetType":"this_entity","targetValue":"","propertyType":"previous_state","propertyValue":"old_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off"},{"id":"kwrzzjeoouo","targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on"}],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":530,"y":320,"wires":[["554ce6a2.5eca18"],[]]},{"id":"554ce6a2.5eca18","type":"stoptimer","z":"1663a5e8.75665a","duration":"30","units":"Minute","payloadtype":"num","payloadval":"0","name":"30min","x":790,"y":380,"wires":[["956c5cb.7f807a"],[]]},{"id":"9092d91.e929428","type":"comment","z":"1663a5e8.75665a","name":"Timer starts when bulb turns on.","info":"","x":870,"y":340,"wires":[]},{"id":"956c5cb.7f807a","type":"api-current-state","z":"1663a5e8.75665a","name":"Motion off?","server":"26956a45.92d866","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"binary_sensor.motion_sensor_158d0000e733ee","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1170,"y":440,"wires":[["baf6e773.797348"],["554ce6a2.5eca18"]]},{"id":"a8a16765.fc1bd8","type":"comment","z":"1663a5e8.75665a","name":"Check if motion.","info":"","x":1140,"y":380,"wires":[]},{"id":"baf6e773.797348","type":"api-call-service","z":"1663a5e8.75665a","name":"Turn off light","server":"26956a45.92d866","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.bulb_bagnetto","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1450,"y":400,"wires":[[]]},{"id":"ea9dff06.cf741","type":"comment","z":"1663a5e8.75665a","name":"Turn off if not motion.","info":"","x":1480,"y":360,"wires":[]},{"id":"4439be70.9326","type":"comment","z":"1663a5e8.75665a","name":"If you want to check every 30 minutes, loop back.","info":"","x":920,"y":480,"wires":[]},{"id":"26956a45.92d866","type":"server","z":"","name":"Hass.io","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
