I am trying to get IFTTT to trigger a script in my Home Assistant installation with the new Nabu Casa integration thingy.
This (https://i.imgur.com/wCilTFO.png) is what I have at the moment in IFTTT. I’m pretty sure this is correct.
Hi @nickjedl, I am trying to trigger an automation via a webhook in home assistant with IFTTT. I also have Nabu Casa and can’t seem to get it to work. Did you use the URL that you get from creating a webhook automation? Or if not, what did you use for the URL? I dont have https set-up other than Nabu Casa.
Nevermind, I figured it out. For anyone else who finds this thread and is wondering the same thing, add IFTTT as an integration, then you will get a URL to use for webhooks.
Thanks for posting your fix! I’m also having issues with IFTTT connecting with Nabu Casa and hass.io. I’m super new to this, so apologies if I get some of the lingo wrong.
I’ve got a script running and working on hass.io, and I’ve got IFTTT integration set up, my questions are;
Do I need anything in the automation.yaml file?
Which URL do I use in the IFTTT applet?
You’ll find your URL in the Webhooks section of your “Home Assistant Cloud” config in HA. It’s under IFFT where you need to enable it first and then you’ll get the URL.
