I put a badge on my screen, which mention correctly if I’m home or not
And a toggle which should do the same (indicating if I’m home)…
Unfortunately the toggle doesn’t react on the 2 triggers I made…why ? Maybe one trigger is enough, but I’m newby…
alias: Zet Christian als thuis
description: ''
- platform: state
entity_id: person.christian
to: HOME
condition:
- condition: state
entity_id: input_boolean.toggle_christian_is_thuis
state: 'off'
- condition: state
state: 'on'
mode: single
alias: Zet Christian als weg
description: ''
- platform: state
to: AWAY
condition:
- condition: state
state: 'on'
- condition: state
state: 'off'
mode: single
Because the states is not HOME or AWAY, it’s home or not_home.
Always look in developer tools for correct states, Lovelace is not a good place to look at states since it will write them differently sometimes.
Keep in mind that not_home means not in any zone. So if you create a zone called work then you will be in work and not not_home
Thanks for the developer tools tip, I’ll keep that in mind.
I’ve omitted the “from” part, because I don’t think it matters here.
I have only the home zone defined for the moment.
Unfortunately it still doesn’t work… (even when I remove the condition-part)
description: ''
- platform: state
to: home
condition:
- condition: state
state: 'off'
- condition: state
state: 'on'
mode: single
description: ''
- platform: state
to: not_home
condition:
- condition: state
state: 'on'
- condition: state
state: 'off'
mode: single
With a device it’s OK (turns on and off the light)
alias: Test - home
description: ''
- platform: state
to: home
condition: []
- type: turn_on
device_id: 7a74e8a0e5c59427d4dd08b85a25577b
entity_id: switch.sfeerverlichting_dressoir
domain: switch
mode: single
alias: Test - Away
description: ''
- platform: state
to: not_home
condition: []
- type: turn_off
domain: switch
mode: single
