Trigger ID
Hi All
Am I being really stupid here (probably as its been a long day) but for the life of me I cant seem to get this to work, or in fact even confirm it should:
PARTIAL AUTOMATION:
  - device_id: df9b3ff7a16e7d73a89b3eadbf63b861
    domain: hue
    platform: device
    type: long_release
    subtype: 4
    unique_id: 850d897b-294c-4ede-b889-b3fa964104ee
  - service: switch.turn_off
    data: {}
      entity_id: switch.{{ trigger_id }}_motion_sensor_motion
I have tried qoutes and no qoutes and constantly get the following results:
Template rendered invalid entity IDs: switch._motion_sensor_motion
What blindingly obvious am I missing here?
PS. I dont normally trigger off of devices but I was just testing and will likely end up using the hue event once I have worked out why I am failing at the first hurdle.
TIA
I believe its ‘trigger.id’. and yes it will work.
    data: {}
      entity_id: switch.{{ trigger.id }}_motion_sensor_motion
btw, you can really just assign any variables to the trigger as well…
  - platform: xxxx
    xxxx
    variables:
      some_trigger: value
    data: {}
      entity_id: {{ some_trigger }}
Thanks @calisro you were of course right it should have been:
 entity_id: switch.{{ 'trigger.id' }}_motion_sensor_motion
Can you do me a favour…just for clarity for others, can you edit your above post yaml to include the ’ ’ and then I can mark it as the solution.
Thanks again mate
You don’t need those quotes. I believe those quotes will make it a literal and make it NOT work as you’d expect.
This is an example from mine.
  - service: lock.unlock
    data: {}
      entity_id: lock.{{trigger.id}}_door
Strange as this logs and error and does not work:
    data: {}
This does not log an error and works:
    data: {}
      entity_id: switch.{{ 'trigger_id' }}_motion_sensor_motion
Put this in the developer tab in your home assistant and you will see what it is doing:
It will literally make it
entity_id: switch.trigger.id_motion_sensor_motion
How are you testing it? Are you trying to execute it manually? The trigger variable wouldn’t be set if you tried to manually execute it.
This may not log an error but it isn’t ‘turning off’ your intended switch quotes in it.
Your right, I have just checked it and although the automation completes without error in the debug its clearly now calling “switch.trigger_id_motion_sensor_motion”
I am checking it by physically triggering the switch.
Paste your entire automation.
This should be what you need:
    domain: hue
    platform: device
    type: long_release
    subtype: 4
    data: {}
assuming you want to turn off
switch.kitchen_motion_sensor_motion
alias: testing
description: ''
  - device_id: eb20d4f24cec0e41a8799f83b1786e09
    domain: hue
    platform: device
    type: long_release
    subtype: 4
    unique_id: 9473b58b-5684-4456-8668-e7d9ef834301
  - device_id: 8855c1e044222311a2da1c90344cc7ad
    domain: hue
    platform: device
    type: long_release
    subtype: 4
    unique_id: cf0b67dd-5683-49f9-92b9-8a346c7d64ef
  - device_id: 5f9ef66105117045126056d40361ffd4
    domain: hue
    platform: device
    type: long_release
    subtype: 4
    unique_id: fddbf3f0-2829-48a9-a7d3-79b13bb00375
  - device_id: 1d7d795402dd6b480d3cc79651517dd4
    domain: hue
    platform: device
    type: long_release
    subtype: 4
    unique_id: dcd3515d-84f5-4135-abc2-f9c35123e102
  - device_id: 9e23fe42623eb447b1b52f90384c1140
    domain: hue
    platform: device
    type: long_release
    subtype: 4
    unique_id: ad4a0d58-bd18-48fc-b0dd-b7630d8d41b8
    domain: hue
    platform: device
    type: long_release
    subtype: 4
condition: []
    data: {}
mode: single
And the error in debug:
Triggered by the event 'hue_event' at 25 July 2022 at 17:39:18
Call service switch.turn_off on templated entities
Stopped because an error was encountered at 25 July 2022 at 17:39:18 (runtime: 0.01 seconds)
But… You still have the wrong thing there. It should be
Well don’t I feel really stupid now.
Thank you so much for your time on this Rob, I really don’t know how I managed to F that up so badly.
Its all working as expected now :+1:
