Hey all,
Goal
I have an automation set up that gets executed on an incoming MQTT message and should then in turn execute a script. That script should then do different things depending on the MQTT topic.
The documentation for scripts says:
When the script is executed within an automation the trigger variable is available. See Available-Trigger-Data.
But when the script gets executed the if condition in the script fails.
Automation
- id: "1668628839844"
alias: Receive Target Temperature
description: ""
- platform: mqtt
topic: 02/00002F71/+/V/A0
condition: []
service: script.update_target_temperatur_slider
mode: parallel
max: 50
Script
update_target_temperatur_slider:
alias: Update Target Temperatur Slider
sequence:
# Vincent
- if:
- condition: template
value_template: '{% if trigger.topic[12:24] == "D43D3914C9DE" %}
{%endif%}'
then:
- service: input_number.set_value
value_template: "{{ int(trigger.payload[1:],base=16)/2 }}"
entity_id: input_number.temp_vinc_2
# more conditions for different topics
Problem
When the automation execute the script fails with the following:
Error: In 'template' condition: UndefinedError: 'trigger' is undefined
This should work according to the documentation above, unless Iām misunderstanding this.
Anyone have an idea on how to make this work?
Thanks.
