Is it possible to trigger on a flow variable?
I have a fairly complex sequence where a variable sometimes becomes NaN.
And this makes it break because this variable is needed in the rest of the sequence, so I need to change this variable to a float value if it by some reason that I don’t understand becomes NaN.
Is there any trigger nodes that can trigger on flow variables becoming NaN?
