Hi Am New to HA
I have successfully flashed Espurna on my sonoff Bridge , I am able to status of my PIR sensor & use in my automation it works fine
Question:
Now I want to switch ON/OFF my generic 433mhz RF socket using home Assitant
I have learned the RF code both ON & OFF for the socket into Espurna Learn interface.
I have added an MQTT switch to my HA (Same as Sonoff Tasmotised switch).
Configuration.yaml
This normally means the state_topic message was not received from the device confirming it had switched state, so HA assumes the switch did not happen. What does the switch send back after the command is sent?
