Trigger on state change only
OK, sorry about this post, feels like such a simple thing but I’ve not been able to find a way of doing it…
All I want to do is trigger an automation on an entity state change, not an attribute change.
This is what I’ve got but it triggers on every attribute change, which i don’t want.
  - alias: cycle nanoleaf on weather change
    initial_state: true
      platform: state
      entity_id: weather.met_office_moor_allerton
    condition:
      - condition: state
        entity_id: light.nanoleaf_aurora_52_4b_ff_local
        state: 'on'
The only way I can see is to add a condition a bit like;
  condition:
    - condition: template
      value_template: "{{ trigger.to_state.state != trigger.from_state.state }}"
But that seems really clunky, is there a simple way to just trigger on state change, not attribute change???
:slight_smile:
Thank you
The solution you found is the way we all do it.
This showed up in a search for me, but the full functionality has been added to HA since this was discussed.
In the visual editor:
In yaml:
  - platform: state
    entity_id:
      - sensor.temperature_30
    to: null
The other way that may help if you don’t want unknown states triggering it is:
  - platform: state
    entity_id:
    not_to:
      - unknown
      - unavailable
