Trigger on sunrise with limits
Hi !
I would like to have a trigger based on sun sunrise/sunset datetime but with some restrictions (like never before 7am) with a single automation (I don’t think I can do that with ‘conditions’).
Something like:
   platform: sun
   event: max(sunrise, "07:00")
The template trigger looks interesting for this but I’m totally lost with the ninja2 syntax.
Can someone help ? :slight_smile:
Yes, you can.
- alias: example
    platform: sun
    event: 'sunrise'
  condition: "{{ now().hour < 7 }}"
    # etc ...
Yes but that will just not trigger the action, never. In my case I would like to postpone it.
How do you want to handle sunrises that occur after 7:00?
- alias: example
    platform: sun
    event: 'sunrise'
  condition: "{{ now().hour >= 7 }}"
    # etc ...
If you want it to happen at sunrise, or 07:00, whichever happens first then:
  1. You need two triggers - sunrise, and 07:00
  2. You need a template condition - to check that the automation hasn’t triggered in the last 12 hours
condition:
  - condition: template
    value_template: "{{ state_attr('automation.YOUR_AUTOMATION','last_triggered') == None or (now() - state_attr('automation.YOUR_AUTOMATION','last_triggered')).seconds > 43200 }}"
Then the first trigger that day will cause the automation to run, whether that’s because the sun rose, or because it’s 07:00.
Thanks Tinkerer, that would work !
In the meantime I was wondering if I could have a template trigger with something like ([‘tomorrow 7h’, ‘sun.sun.next_dawn’]|min), but I don’t know jinja2 enough.
I may have a look at the sun trigger code directly to add optional ‘never_before’/‘never_after’ settings.
