I’m trying to fire an MQTT message each time the temperature changes. This works when I run it manually, but doesn’t trigger on every temperature change:
It doesn’t trigger at all. The trace says the node was not executed. It does show it as executing successfully when I run it manually, but it never executes based on a change in the temperature.
This is working now, although I’m not sure exactly why. I tried changing the Trigger Type to numeric state with a value of From: 0. Didn’t work, so changed the Type back to just “state” and now it’s firing. Although it seems to fire on anything within the state object that changes, not just the temperature. But I’ll take it for now.
