Hi all,
I have a wave door sensor and nest thermostat.
I want the nest to be set to away after the door being open for 5 minutes and send me a notification. I’ve got this working.
When the door closes the nest should go back to its normal state and send me a notification. I’ve also got this working.
The problem is that now whenever the door closes I get a notification. I could set the condition to only send the event when the nest is away and the door closes but I would still get notifications when the nest is manually set away.
Is there a way to only trigger the door close sequence after the door open sequence has run?
Thanks!
