Trigger only from a given state to another one
In HA automations there is an option to trigger an automation if a state change from a state to another one. E.g. a sensor has 4 states: One,Two, Three, Four and I wan’t to trigger an automation when the sensor goes to Four from Two, but do not trigger when it goes Four from One or Three. It is possible whith a normal HA automation with filling the “From:” and “To:” fields in the triiger.
But how can I do this in Node-Red?
(And also wondering how can I make a template sensor to change only when another Sensor goes to a state from a given previous state, but this is not related to this subtopic…)
You can use a Trigger State Node.
You can set conditions based on both the current state and the previous state - if all conditions are true it’s routed to one output, if any are false it routes to another (which can be ignored, if you don’t want to do anything with it).
Thanks a lot. And how stupid I am, I used the Trigger state before :frowning:
Thank you again! :slight_smile:
No problem, you might want to consider marking it as the answer to help others in future.
