New Feature
Trigger Five - Increment Duration - Every time the button helper is pressed, it increments the timer’s remaining time by a specified duration set in the Increment Duration (e.g., 15 minutes). The value is dynamically added to the timer’s remaining time, ensuring the timer’s duration continues to increase with each press of the button helper.
This input is ideal for scenarios where you need to extend the timer’s duration repeatedly, such as when additional time is required for tasks, without resetting the timer completely.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
