Trigger,slots not firing
A while ago I created an automation using the trigger.slots method and it works well, I am trying to do a similar but much simpler thing and it’s just not firing, any tips would be great. thanks.
I have tried…
service: input_number.set_value
metadata: {}
  value: {{ (trigger.slots.temp) }}
  entity_id: input_number.dro_max_temp
metadata: {}
  value: {{ trigger.slots.temp }}
and
metadata: {}
  value: { trigger.slots.temp }
The trigger variable is only defined in automations.
Assuming you are actually using automations, here, and that you are not just “running” the automation manually, which doesn’t define the trigger variable, please show the full automation(s).
Hi, yes it is part of a automation, here is the complete thing.
alias: Speech Testing
description: ""
  - platform: conversation
    command:
      - Set Dining room temperature to {temp}
condition: []
  - service: input_number.set_value
    metadata: {}
mode: single
As I said I have used something similar before, and actually a lot more complex (See below) and works beautifully, I am obviously missing something.
alias: Where is anyone
description: ""
    command:
      - Where is {name}
condition: []
  - service: media_player.play_media
      entity_id: media_player.office_display
      media_content_id: >-
        media-source://tts/cloud?message={{ states('sensor.' ~
        trigger.slots.name | lower | replace('?', '') ~ 'cl')
        }}.&language=en-IE&gender=female
      media_content_type: provider
    metadata:
      title: Who is where.
      thumbnail: https://brands.home-assistant.io/_/cloud/logo.png
      media_class: app
      children_media_class: null
      navigateIds:
        - media_content_type: app
          media_content_id: media-source://tts
        - media_content_type: provider
mode: single
You say it’s not firing, right?
So I guess the command is just not recognized. What does the assistant debug tells you?
It is recognising the speech no problem, it seem to be something to do with the value.
I have tried this…
description: ""
    command:
condition: []
    metadata: {}
      value: {{trigger.slots.temp|float}}
mode: single
And am still getting this error.
expected float for dictionary value @ data[‘value’]
I think this might a be a limitation of the input number helper.
In my other automation I can add the variable in the UI, as below…
And then it is in the YAML
    media-source://tts/cloud?message={{ states('sensor.' ~ trigger.slots.name |
    lower | replace('?', '') ~ 'cl') }}.&language=en-IE&gender=female
In the input number if try to add it to the UI it just wont let me…
It will only let me enter a number…
If I add it in the YAML,
description: ""
    command:
condition: []
    metadata: {}
mode: single
Save it and go back to the YAML it has changed it to this…
description: ""
    command:
condition: []
    metadata: {}
      value:
        "[object Object]": null
mode: single
Ah, jinja templates must always be enclosed with quotes. YAML continuation works as well, as in your working example.
Chris, Thank you…
I didn’t know that bit you’ve been a massive help.
