Noob here, spent the past few hours digging through forums and documentation but seem to be hitting a roadblock hoping you guys can help me with.
Goal:
Ping a local IP address, on failure, power cycle a smart plug
Progress
D-Link smart plug setup manual integration with (through configuration yaml file), works great no issues.
I’ve also setup a binary_sensor
for ping
to ping the server (powered through the dlink outlet), which appears to work correctly as well.
switch:
platform: dlink
host: 10.0.0.50
username: admin
password: XXXXX
binary_sensor:
- platform: ping
host: 10.0.0.99
scan_interval: 30
I’m having issues though figuring out how to setup a trigger to power cycle the dlink outlet, as it does not show up as an actual “device” per-say. Because of this, does that mean that my automation would need to somehow set the state
from on
to off
then from off
to on
This is where i’m getting stuck at, i’m not sure how I would go about doing a power cycle on the dlink device when the ping fails, can anybody help me out or point me in the right direction please?
Reference
I have a very old server that needs to be updated/upgraded but I have not had the time yet to buy new parts, and the easiest solution for me to deal with it for now is to just power cycle. If I could get this automation setup and working it could buy me a little more time to get the funds and parts together to do the upgrade, without much downtime.
Thanks!!
