hi all,
i’m trying to workout how to start a flow only if the temp changes on my thermostat. I can see easily how to trigger it if it’s below something but can you trigger it if the value has changed?
thank you
hi all,
thank you
Ideally i just want to have a flow that takes the ecobee temp state
If < 15 temp = Cold
if > 24 temp = Hot
i’d like these as message payloads to go to a switch/logic so i can just work with hot and cold then if that makes sense
but i can’t workout how to set it up
it’s outputing flows as Blocked/Allowed/<15 and >24
custom message needs to be a complete object
{"payload": "Cold"}
or use the custom payload “Cold”
thank you very much.
so i’ve set it like this
so that should output message as it states if either state is true? thank you
yes, it should.
Look at the filter node. In RBE mode the filter node will block until the msg.payload
value is different to the previous one.
