I’m trying to notify myself when a plant gets below a specific humidity, but the notification only got sent once, here’s my configuration, can you find out what I’m doing wrong?
You’ll have to separate the entities out in your trigger to get the behavior you want. Groups do not average the results of a series of sensors. That’s why you have to break them out. Also, your spacing is off in your automation:
Hi @petro thanks for noticing the indentation, that’s because I indented manually in this community post. Unfortenately changing it into the list of entities didn’t work. This is my groups.yaml:
Nope, and they’re both below 50… my first thought is that once one of them comes above 50 the trigger will be reset, I guess I’ll have to water them to find out
They have to cross for it to trigger. I.E. start above, then cross below. Or they just have to update when below. If you are restarting, that’s probably not happening.
