Trigger Sun Offset Template in Blueprint
Mostly everything in HA accepts a template
But Sun a trigger offset is not accepted I don’t know why
Even it accepted the template in the blueprint from Input selected or Input number
like this example below
  input:
    Sunrise_Offset:
      description: Offset time After Sunrise event.
      selector:
        select:
          options:
            - label: None
              value: "00:00:00"
            - label: 15 Min
              value: "00:15:00"
  platform: sun
  event: sunrise
  offset: !input Sunrise_Offset
# or
  input:
    hours:
      name: Sunrise Offset Hours
      description: Offset in Hours After Sunrise event.
      selector:
        number:
          min: 0
          max: 6
    minutes:
      name: Sunrise Offset minutes
      description: Offset in minutes After Sunrise event.
      selector:
        number:
          min: 0
          max: 59
  platform: sun
  event: sunrise
  offset:
    hours: !input hours
    minutes: !input minutes
    seconds: "00"
for that, we need to expand this to helpers like input_number or input_select to be able to control this time from the front end
Use A time selector
  input:
    sunrise_time:
      name: Sunrise - Offset - time
      description: Offset the sunrise time.
      default: "-1:00:00"
      selector:
        time: {}
  platform: sun
  event: sunrise
  offset: !input sunrise_time
hi @DefenestrateIT Thanks for your replay
I knew this methode my request about use template to order to control it from front-end not inside blueprint
Then you will probably need to convert a number (integer) to time & use - platform: template
lets say we have two helper input_number one control H and other Control Min how to it in template inside blue print
any ideas ?
I wouldn’t, just keep everything as time.
if I want to offset the sunrise time by + 1hr & 35 min’s
    sunrise_time:
      default: "1:35:00"
      selector:
        time: {}
if i wanted to subtract the that time
    sunrise_time:
      default: "-1:35:00"
      selector:
        time: {}
if I wanted it on a dashboard I would use A time helper &
  input:
    sunrise_time:
      selector:
        entity:
          domain: input_datetime
@DefenestrateIT can use input_datetime directly without
  input:
    sunrise_time:
      default: "-1:00:00"
      selector:
        entity:
like using
variables:
if it works, please provide example
I don’t understand…
What are you trying to do?
I assume you want to make a blueprint with A trigger at sunrise, but you want to offset that time, Correct?
Why don’t you want to use the time selector?
If you want to know where to make a time helper…
Settings > Devices & Services > Helpers
I assume you want to make a blueprint with A trigger at sunrise, but you want to offset that time, Correct? yes
Why don’t you want to use the time selector? to keep everything fixed not changeable for that I try not use selector
So you want to have a trigger for A particular time all year?
  - platform: time
    at: !input sunrise_time
not fix all time that point i can change it from dashboard
So you don’t want it on A dashboard? then:
Otherwise why aren’t you doing this as an Automation-Script? Why are you trying to make a blueprint?
Settings > Automations & Scenes
  platform: sun
  event: sunrise
  offset: 01:35:00
to keep everything simple UI for that I prefer to use a blueprint in case I need to change
my question
Is there a way to use any type of helper to modify the offset in the blueprint without using the sector method?
like import ( input_datetime or input_number or input_select ) State through (variables: ) to blueprint
like this example
       minutes: "{{ states('input_number.minutes')|int(0) }}"
Actually, I use this template
{{ states('input_select.sunrise_after_offset_hour') }}:{{ states('input_select.sunrise_after_offset_min') }}:00
Screenshot (5)
any way to use it blueprint without using the sector method?
A blueprint won’t make it simple. Blueprints are only any good if you want to reuse the same code.
If you want to Hard Code a time, you can.
Why do you want to use variables?
Your Entity’s are both “input_select” which has a string (word) value, so your approach from the beginning just makes everything 100 times harder. you want to use either “input_number.” or preferably “input_datetime.”
But if you must use a “input_select” then use a “choose” function (if functions for templating) to convert from a “string” to “time”.
Exactly reuse the same code without the need to create it again
to minimize UI in Blueprint
I use input_select because it gives me a nice drop list in the Dashboard
it’s ok to switch input_number not a problem in that
for input_datetime My local Time use AM/PM when I use input_datetime it makes it confusing for that I avoid it for this type of configuration
any example, please
Don’t think of “input_datetime” as AM/PM it is time. if you want to use it as AM/PM you can or 24hr or Hours:Minutes:Seconds
Not today, i’m going to bed. but your problem is that you want to use it as A trigger so the templating is diffecult, but an E.g.
{{ 15 if input_select.sunrise_after_offset_min == '15 mins' }}
Ok dear GoodNight
Exactly difficult because using it as a trigger “not part of the action”
According to my reading in many posts Offset in Trigger Sun is unable to templating even in normal Automation for that using elevation or azimuth method to solve this problem
All that can solve by accepting Offset for templating this what I requested in this post
