I use 433mhz kaku switches to control my lights, these switches can be controlled by a physical wallswitch and with Rf 433mhz.
The ‘problem’ is that the switches don’t give ‘feedback’. For example when a lights is turned on manually it stays in the off state in Hass. When I give Hass (by Google home for example) the command to turn off “all lights” nothing happens for the light since it is already in the off state.
Is there a possibility to trigger a switch that is already in the requested state? For example when I activated “turn all lights of”, I want that the off command will be published (mqtt) also for the lights that are already off?
