Hi All,
I am trying to build a template sensor that updates 1 second before every 15 min on of the hour, So i need it to trigger at 1:14:59, 1:29:59, 1:44:59, 1:59:59 etc… I have a trigger thats working for every 15 min but dont know how to make it trigger before the 15th min reliably
This is my current trigger
- trigger:
- platform: time_pattern
minutes: “/14”
second: “59”
This works and trigger on the 1:14:59 but will trigger at 02:00:59
Any help would be great.
“/14” means divisible by 14, so 14, 28,etc. Normal cron would support the following:
59 14,29,44,59 * * * * *
So you could try:
minutes: "14,29,44,59"
second: "59"
I have not tested.
I think it’s got to be 4 time pattern triggers…
minutes: "14"
seconds: "59"
minutes: "29"
seconds: "59"
minutes: "44"
seconds: "59"
minutes: "59"
seconds: "59"
This is the way, though one slight change to the solution you have posted. It seconds not second It took me a while to trouble shoot that one as the output from logs on template sensor are not great!
updated with seconds not second
