Trigger Template
I’m trying to create an automation that sends a notification when a window is open for a longer period of time in winter.
This is what works so far:
alias: Fenster auf (Generic)
description: Sends a notification if a window is open for a longer period of time in winter
  - platform: state
    entity_id: binary_sensor.zb2_b_wz_door
    to: 'on'
    for: '00:15:05'
  - platform: state
    entity_id: binary_sensor.zb2_c_bo_window
    to: 'on'
    for: '00:15:05'
  - platform: state
    entity_id: binary_sensor.zb2_f_window_flur_ias_zone
    to: 'on'
    for: '00:15:05'
  - platform: state
    entity_id: binary_sensor.zb2_a_fu_door_ias_zone
    to: 'on'
    for: '00:15:05'
  - platform: state
    entity_id: binary_sensor.zb1c_window
    to: 'on'
    for: '00:15:05'
condition:
  - condition: numeric_state
    entity_id: sensor.openweathermap_temperature
    below: '15'
  - service: notify.mobile_app_inspektor_gadget
      message: >-
        {{ sensors[trigger.entity_id].name}} im {{
        sensors[trigger.entity_id].room}} ist auf.
mode: restart
variables:
  sensors:
    binary_sensor.zb2_f_window_flur_ias_zone:
      room: Flur
    binary_sensor.zb2_a_fu_door_ias_zone:
      room: Flur
    binary_sensor.zb2_b_wz_door:
      room: Wohnzimmer
    binary_sensor.zb1c_window:
      room: Bad unten
    binary_sensor.zb2_c_bo_window:
      room: Bad oben
I got the notification generated dynamically based on the sensor - defined in a variable. I’m now trying to get the trigger (state change from off to on for 15min) into a template but I just can’t get it working.
Any ideas how to tackle this?
Thanks for your help,
Robert
What I understand is, that this is basically working, but you want to refactor your trigger to not be so redundant and instead use templating. However, that seems to be quote hard for me. Instead I would suggest to use a group.
You could then trigger on the group change and have the service notify you on the elements true within that group.
Yes, exactly. Since I have the sensors already defined as variables for the notifications it would be great if I can simply use this also for a trigger. So I don’t have to define it twice.
Currently, you cannot use variables in a Template Trigger.
You may wish to cast a vote for the following Feature Request, to allow for variables in a Template Trigger:
Here is another way to achieve your goal of minimizing duplication. Instead of using variables to store each binary_sensor’s name and room, store this information as a custom attribute.
By creating custom attributes, called name and room, they become part of the entity, will appear in the entity’s list of attributes (shown in the Attributes column in Developer tools > States), and are accessible by any template (using the state_attr() function).
You can create custom attributes by adding them to the customize.yaml file or via the UI with Configuration > Customizations. Here is the documentation for Customization.
For your purposes, the customize.yaml would contain this:
  room: Flur
  room: Flur
  room: Wohnzimmer
  room: Bad unten
  room: Bad oben
The automation can be reduced to this:
  - platform: state
    entity_id:
      - binary_sensor.zb2_b_wz_door
      - binary_sensor.zb2_c_bo_window
      - binary_sensor.zb2_f_window_flur_ias_zone
      - binary_sensor.zb2_a_fu_door_ias_zone
      - binary_sensor.zb1c_window
    to: 'on'
    for: '00:15:05'
condition:
    below: '15'
      message: >-
        {{ state_attr(trigger.entity_id, 'name')}} im {{
        state_attr(trigger.entity_id, 'room')}} ist auf.
Hi @123,
thanks a lot for your clarification. I left a vote. Meanwhile I implemented your suggestion. This makes it already a lot cleaner.
Robert
If you are interested, I explained other uses for custom attributes here:
Thank you! I like the approach. It’s quite useful :smiley:
