Hi everybody,
I am trying to convert multiple automations into one, using trigger.to_state
to determine what is supposed to happen.
alias: Triggertest
description: ""
triggers:
- trigger: time
at: input_datetime.triggertest_az_00
- trigger: time
at: input_datetime.triggertest_az_01
- trigger: time
at: input_datetime.triggertest_wz_00
- trigger: time
at: input_datetime.triggertest_wz_01
conditions: []
actions:
- variables: {}
mode: single
How do I go from here? I would like to use input_number.set_value
, where the pattern is input_number.triggertest_az_00
, input_number.triggertest_az_01
, input_number.triggertest_wz_00
, input_number.triggertest_wz_01
, depending on the entity_id
of the input_datetime
, which triggers this automation.
Concrete example:
if triggered by input_datetime.triggertest_az_00
, then input_number.set_value
the entity input_number.triggertest_az_current
to the value of input_number.triggertest_az_00
. Then, of course:
if triggered by input_datetime.triggertest_wz_01
the entity input_number.triggertest_wz_current
to the value of input_number.triggertest_wz_01
So always set xyz_current
(where xyz is the abbreviation for the room) to the input_number
s state, which it gets from the input_datetime
s entity id.
Basically, what’s going on here is that at certain I want climate
entities to be set to specific values. There is always (...)_00
up to (...)_04
per room. Currently, these are all separate automations - and they are using trigger ids.
However, this seems like a case for trigger.to_(...)
, right? I just can’t figure out how to do it.
Hopefully I have explained this in a way people can understand. If not, sorry, please ask and I’ll try my best to clearify.
Thank you in advance for your help
