Trigger troubble
Hi there.
Why does not this automatisation trigger:
- id: '1574892412940'
  alias: Nattsenking av temp
  description: Slar ned temperaturen etter klokken 00.00 til 16 grader
  - at: 00:18
    platform: time
  condition: []
  - data:
      hvac_mode: heat
      temperature: 16
    service: climate.set_temperature
Put 00:18 in quotes “00:18”
What makes you think it is not triggering? Maybe it is triggering but nothing happens because the automation’s action is incorrect. For example, the action calls the service climate.set_temperature but fails to specify the entity_id.
