Trigger using input_datetime with time offset
I have used [sleep alarm to HA] to create an input.datetime helper in my HA. This all works well.
I wrote this code to activate the wake up light. However the trigger does not like the time offset. I have used various options but all do not work. I would like some help by setting up the trigger properly to the wake up light starts 20’ before the actual alarm.
alias: Wake Up Light
description: Gradually increase light brightness to a defined percentage before wake-up time
  - platform: time
    at: >
      {{ (states('input_datetime.yphone_alarm') | as_datetime - timedelta(minutes=20)).time() }}
variables:
  max_brightness: 102 # 40% of 255
  - service: light.turn_on
      entity_id: light.bedroom_spots
      brightness: 5
  - delay: "00:00:30"
  - repeat:
      while:
        - condition: template
          value_template: >
            {{ state_attr('light.bedroom_spots', 'brightness') | int < max_brightness }}
      sequence:
            brightness: >
              {{ [state_attr('light.bedroom_spots', 'brightness') | int + 5, max_brightness] | min }}
        - delay: "00:00:30"
  - service: logbook.log
      name: "Wake Up Light"
      message: "Brightness reached {{ state_attr('light.bedroom_spots', 'brightness') }}."
Does this work?
    value_template: "{{ (as_timestamp(states('input_datetime.yphone_alarm')) - 1200) | timestamp_custom('%H:%M:%S', false) == states('sensor.time').state }}"
variables:
      brightness: 5
  - delay: "00:00:30"
  - repeat:
      while:
          value_template: >
      sequence:
            brightness: >
        - delay: "00:00:30"
Why not use the offset attribute of the trigger. Take a look at the docs.
Templates are not supported everywhere. The majority of the different types of triggers and condition do not allow templates.
If you want to use a template like that, to calculate a time for a trigger you need to use a Template trigger (as demonstrated above by Colton). Though I would suggest using the following simpler version:
{{ now() >= states('input_datetime.yphone_alarm')|as_datetime|as_local - timedelta(minutes=20) }}
However, as long as your offset is static, you would be better served using the built-in offset attribute (added in 2024.9) that Pete has linked to.
no unfortunately not.
  - platform: time
    at:
      entity_id: input_datetime.yphone_alarm
      offset: "-00:20:00"
This does not work because as far as I understand you can not use "at: input_datetime.xxx in combination with offset: xx
This is my not working code:
description: >-
  time
triggers:
  - trigger: time
    at: input_datetime.yphone_alarm
      offset: -00:20:00
actions:
  - target:
      brightness: 5
    action: light.turn_on
  - delay: "00:00:30"
  - repeat:
      while:
          value_template: >
            max_brightness }}
      sequence:
        - target:
            brightness: >
        - delay: "00:00:30"
  - data:
      name: Wake Up Light
      message: >-
    action: logbook.log
variables:
  max_brightness: 102
Compare to what I wrote
Ya, that didn’t work for me either, see photo attached, and what DID work.
BUT… This DID!
Are you running an old version of HA? Working fine over here.
You need to be on 2024.10+
Don’t think so:
  • Core: 2024.11.3
  • Supervisor: 2024.11.4
  • Frontend: 20241106.2
Is that message from the VSCode addon? If yes, the addon is wrong. This is a recent change in HA and works perfectly.
No, it’s in the automation configuration page.
Well somethings wrong with your system. I took the screenshot from the same version. I even worked on that section of code recently. The YAML I provided 100% works.
How would I troubleshoot this then?
PS: here’s screenshots of both your code and mine showing yours giving me that error and mine working fine. I know it’s apples and oranges. I’d like to figure out why yours doesn’t work on my system though…
Well apparently it’s restricted to sensors only, not input_datetimes and sensors. I’ll put in a PR to amend that
Oh, okay. Thank you for doing that! Sorry to make more work for you!
I’ve just read up with the threat. This is indeed the problem. The helper input_datetime is not considered a sensor and thus does not work. When can we expect an update of HA?
PRs can take anywhere between 2 and 4 months to complete
