hi
I’m writing my first automation. I have two problems:
first problem
- platform: time
at: 00:30
condition:
- condition: numeric_state
entity_id: sensor.solar_forecast_today
below: '5'
<not had any issues here>
I want to test that the condition logic does the right thing. I beat my head against this one for two days because the action would always fire no matter what the condition, then I found deep in this forum in a couple of postings, that a manually triggered automation ignores all conditions I did rtfm in depth but did not find it.
so how do you workaround this - how do you test that a condition evaluates the way that you want it to, without waiting for the trigger event?
second problem:
can you build in one automation a more sophisticated logic that takes same action with different value based on different conditions? it would seem ugly to have to write this as 3 separate automations triggering a few mins apart?
i.e.
numericstate_of_entity above A below B do action1 with value X
numericstate_of_entity above B below C do action1 with value Y
numericstate_of_entity above C below D do action1 with value Z
etc
This service will trigger the action of an automation. By default it bypasses any conditions, though that can be changed via the skip_condition attribute.
Use the automation trigger service in Developer Tools Services and make sure you set the skip_conditions option to false.
I think this has been nicely clarified in the latest versions, rather than “trigger” it now says “run actions”
It would be nice to have a button that says “test conditions” and a tick appears next to each condition that is true
