I am migrating from Openhab to HA and am still on a steep learning curve.
I’m trying to create a really simple rule, which is pushing a button on the Aeotec Wallmote, and Pause/Playing a Sonos speaker. It’s my first rule and I can’t get it to fire.
I have updated my zwcfg file to ensure it is properly recognised, per https://www.home-assistant.io/docs/z-wave/device-specific/#aeotec-wallmote
The Zwave log shows that it sees the scene change:
2019-10-05 11:46:43.949 Detail, Node008, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x08, 0x05, 0x5b, 0x03, 0x89, 0x00, 0x01, 0x2d
2019-10-05 11:46:43.949 Info, Node008, Received Central Scene set from node 8: scene id=1 in 0 seconds. Sending event notification.
2019-10-05 11:46:43.949 Warning, Node008, No ValueID created for Scene 1
2019-10-05 11:46:43.969 Detail, Node008, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x08, 0x07, 0x60, 0x0d, 0x01, 0x00, 0x20, 0x01, 0x00, 0xb4
2019-10-05 11:46:43.969 Info, Node008, Received a MultiChannelEncap from node 8, endpoint 1 for Command Class COMMAND_CLASS_BASIC
2019-10-05 11:46:43.969 Info, Node008, Received Basic set from node 8: level=0. Sending event notification.
2019-10-05 11:46:43.969 Detail, Node008, Notification: NodeEvent
2019-10-05 11:46:43.988 Detail, Node008, Received: 0x01, 0x0e, 0x00, 0x04, 0x00, 0x08, 0x08, 0x60, 0x0d, 0x01, 0x00, 0x26, 0x01, 0x00, 0xff, 0x41
2019-10-05 11:46:43.988 Info, Node008, Received a MultiChannelEncap from node 8, endpoint 1 for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
And my rule is simply:
- id: 'OfficeMusicToggle'
alias: 'Office Music Pause-Play'
platform: event
event_type: zwave.scene_activated
event_data:
entity_id: switch.aeon_labs_zw129_wallmote_duo_switch
scene_id: "1"
scene_data: 0
condition:
service: notify.notify
data_template:
message: >
Button pressed
Can anyone please suggest what I’m missing?
TIA.
