Triggering Alexa media player from a templated script
Hopefully it’s just something really obvious that I’m missing but here goes.
I’m trying to set up a multiroom audio setup on my Amazon Echos to trigger some preset playlists which are selected via input_select and the target is also set via another input_select.
So far I have the input_selects set up without issue, and they’re setting a templated sensor to set the correct target and media type:
  sensors:
    audiocaster_target: # Used to determine target for audio casting
      unique_id: 65887a2b-d04f-437e-a4ae-90c421254fc5
      value_template: >
        {% if is_state("input_select.select_media_player", "Living Room") %}
          media_player.living_room
        {% elif is_state("input_select.select_media_player", "Kitchen") %}
          media_player.kitchen
        {% elif is_state("input_select.select_media_player", "Master Bedroom") %}
          media_player.master_bedroom
        {% elif is_state("input_select.select_media_player", "Guest Bedroom") %}
          media_player.guest_bedroom
        {% elif is_state("input_select.select_media_player", "Office") %}
          media_player.office
        {% elif is_state("input_select.select_media_player", "Everywhere") %}
          media_player.everywhere
        {% endif %}
    audiocaster_media_type:
      unique_id: 65887a2b-d04f-437e-a4ae-90c421254fc6
      value_template: >
        {% if is_state("input_select.select_media", "Kerrang Radio") %}
          TUNEIN
        {% else %}
          AMAZON_MUSIC
        {% endif %}
This gives me the correct target and media type, so no issue there.
Next I have created the following script which I intend to populate with these values and trigger from a button:
audiocaster:
  sequence:
  - service: media_player.play_media
    data_template:
      target: '{{ states("sensor.audiocaster_target") }}'
        media_content_id: '{{ states("input_select.select_media") }}'
        media_type: '{{ states("sensor.audiocaster_media_type") }}'
  mode: single
  alias: Audiocaster
But this consistently fails with:
Failed to call service script/audiocaster. extra keys not allowed @ data['target']
Any ideas what I’m doing wrong here?
And in addition, if I change the script to:
That fails with a different issue:
Failed to call service script/audiocaster. dictionary update sequence element #0 has length 1; 2 is required
