Hey there,
i’ve tried to set up an MQTT automation to control my shutters, that i wake up “dynamically”. Therefore I have to setup a script, which publishes MQTT topics with a short time period (delay 3 minutes) between them.
Therefore I’ve created the following:
/config/automations.yaml
- alias: Move shutter up
value_template: '{{ states.sensor.time.state == states.input_datetime.alarm_time.state[0:5] }}'
condition:
condition: state
entity_id: input_boolean.shutter_wakeup
state: 'on'
service: script.cover_wakeup
/config/scripts.yaml
cover_wakeup:
alias: Wake Up
description: 'Slowly moves up the cover'
fields:
minutes:
description: 'Amount time between cycles in minutes'
example: 1
sequence:
- alias: Shutter wake 1
service: cover.open_cover
entity_id: cover.rolladen_wake1
- delay:
# supports seconds, milliseconds, minutes, hours
minutes: 3
- alias: Shutter wake 2.1
entity_id: cover.rolladen_wake2
- delay:
minutes: 3
- alias: Shutter wake 2.2
- delay:
minutes: 3
- alias: Shutter wake 2.3
/config/configuration.yaml
input_boolean:
node_red:
name: Node Red Watchdog
initial: on
# Switch for the shutter automation
shutter_wakeup:
name: Rolladen - auto
# Input time for shutter automation
input_datetime:
alarm_time:
has_date: false
has_time: true
now, i’ getting the following errors:
1.)
Fri Mar 06 2020 23:25:25 GMT+0100 (Mitteleuropäische Normalzeit)
Error saving event: <Event state_changed[L]: entity_id=input_datetime.alarm_time, old_state=<state input_datetime.alarm_time=23:43:00; editable=False, has_date=False, has_time=True, hour=23, minute=43, second=0, timestamp=85380, friendly_name=Uhrzeit @ 2020-03-06T23:25:22.775296+01:00>, new_state=<state input_datetime.alarm_time=23:26:00; editable=False, has_date=False, has_time=True, hour=23, minute=26, second=0, timestamp=84360, friendly_name=Uhrzeit @ 2020-03-06T23:25:25.216730+01:00>>
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1246, in _execute_context
cursor, statement, parameters, context
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/default.py", line 588, in do_execute
cursor.execute(statement, parameters)
sqlite3.DatabaseError: database disk image is malformed
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 348, in run
session.flush()
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2479, in flush
self._flush(objects)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2617, in _flush
transaction.rollback(_capture_exception=True)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/langhelpers.py", line 68, in __exit__
compat.reraise(exc_type, exc_value, exc_tb)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 153, in reraise
raise value
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2577, in _flush
flush_context.execute()
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/unitofwork.py", line 422, in execute
rec.execute(self)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/unitofwork.py", line 589, in execute
uow,
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/persistence.py", line 245, in save_obj
insert,
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/persistence.py", line 1137, in _emit_insert_statements
statement, params
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 982, in execute
return meth(self, multiparams, params)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/sql/elements.py", line 293, in _execute_on_connection
return connection._execute_clauseelement(self, multiparams, params)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1101, in _execute_clauseelement
distilled_params,
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1250, in _execute_context
e, statement, parameters, cursor, context
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1476, in _handle_dbapi_exception
util.raise_from_cause(sqlalchemy_exception, exc_info)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 398, in raise_from_cause
reraise(type(exception), exception, tb=exc_tb, cause=cause)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 152, in reraise
raise value.with_traceback(tb)
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
[SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id) VALUES (?, ?, ?, ?, ?, ?, ?)]
[parameters: ('state_changed', '{"entity_id": "input_datetime.alarm_time", "old_state": {"entity_id": "input_datetime.alarm_time", "state": "23:43:00", "attributes": {"editable": fa ... (668 characters truncated) ... -06T22:25:25.216730+00:00", "context": {"id": "839f883d3eda42c28603767caa58ce73", "parent_id": null, "user_id": "bb66043e7eaf4ec582de8721b47539dc"}}}', 'LOCAL', '2020-03-06 22:25:25.216806', '2020-03-06 22:25:25.251274', '839f883d3eda42c28603767caa58ce73', 'bb66043e7eaf4ec582de8721b47539dc')]
(Background on this error at: http://sqlalche.me/e/4xp6)
2.)
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id) VALUES (?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{"entity_id": "input_datetime.alarm_time", "old_state": {"entity_id": "input_datetime.alarm_time", "state": "23:43:00", "attributes": {"editable": fa ... (668 characters truncated) ... -06T22:25:25.216730+00:00", "context": {"id": "839f883d3eda42c28603767caa58ce73", "parent_id": null, "user_id": "bb66043e7eaf4ec582de8721b47539dc"}}}', 'LOCAL', '2020-03-06 22:25:25.216806', '2020-03-06 22:25:25.251274', '839f883d3eda42c28603767caa58ce73', 'bb66043e7eaf4ec582de8721b47539dc')] (Background on this error at: http://sqlalche.me/e/4xp6)
I’m not familiar with yaml and homeassistant. Can anyone help me to fix this issue?
Thank you for your response
