Triggering an event based on fan device speed
I have some ceiling fans that are only controlled by remote controls so I installed a bond bridge to control the fans. I also installed Z-Wave fan speed switches that I can also see in Home Assistant. Since the fans do not respond to a normal in-wall speed switch the output of the switch isn’t connected to the fan but the switch is intended a physical device to trigger events in Home Assistant. I know how to control the fan using the HA and the Bond Bridge, but I cannot figure out how to trigger an automation when the fan switch changes from off to a specific speed value (low, medium, high). The only trigger I see is on/off. What do I trigger on to catch off to low, low to medium, etc?
Thanks!
