Triggering end of a timer and call an action
Hello!
I’m new with Home Assistant and just set up everything new in my house (coming from Homey). I think HA is amazing so far. :grinning: But now im struggeling with some basic timer. I’m not a coder but wanna learn that slowly now. It’s fun!
I created a timer with the helpers with entity name timer.flur_tags.
I’m starting that timer sucessfully with an automation
  - service: light.turn_on
    data: {}
      entity_id: light.flur_schiene_komplett
  - service: timer.start
    data: {}
      entity_id: timer.flur_tags
But now I’m struggeling turning the lights off when timer is done. I can’t save the automation and HA is telling me Message malformed: expected dict for dictionary value @ data[‘event_data’]:
alias: Flurlicht aus nach Timer
description: ''
mode: single
  - platform: event
    event_type: timer.finished
    event_data: timer.flur_tags
condition: []
  - service: light.turn_off
      transition: 10
Still after lots of research I didn’t really find a solution.
Could you please help me? Thanks a lot!
Sebastian
I’ve never used that event but try this instead to see if it works:
  - platform: event
    event_data:
When in doubt, refer to the examples in the documentation (which demonstrates how to use an Event Trigger for a timer and, like finity suggested, the issue is indentation of event_data's entity_id option).
Is that timer something you want to control via the UI or is it more like a “set” time that’s always the same? Like “turn off the light after five minutes”?
If the latter, I wouldn’t use a timer, just set the time in the automation or use a “state” time for it. From your naming of the light, I assume you want your hallway light on for five minutes after it was turned on. This would be a very simple automation, no timers or other fancy things needed. :slight_smile:
alias: Flurlicht aus nach fünf Minuten
description: ''
mode: single
  - platform: state
    to: 'on'
    for: '00:05:00'
condition: []
      transition: 10
In fact I studied the documentation. And I already tried what finity suggested. But I guess that time I still had another error so I didn’t work. But thanks for your help, 123Taras!
Thanks finity, that was exactly what caused the trouble in the end.
That’s an very intersting way of doing that as well, Patrick. Just triggering if the light was turned on. I will defnitely consider that solution as well. Only thing is, I had the idea of turning it on by a motion sensor and only then using the timer. In your case it always turns off after 5 min, also when I turn it on manually, right?
Thanks a lot!!!
:slight_smile: You need to differentiate what you want with the timer. The part where it goes this or that way, is how do you want your timer to be set?
If the timer is kind of constant (read: the time doesn’t get changed often/manually), you use an offset, like I did in the example. If you need the timer to be adjustable in the frontend, you use a “timer” component (like you did).
It doesn’t matter for the other stuff, it’s just depending on the timer.
Whatever it is that triggers your automation, a sensor for ie. the temperature, a binary_sensor like a motion sensor or a door contact, a template sensor, as long as it has a state, it can be the trigger (and following a state timing like “for”). :slight_smile:
You can even set conditions for the offset. To stay with your example, you could differentiate between manually switched on or by motion sensor. Eg. turned on manually => turn off after three minutes, turned on by motion => switch off after 30 seconds.
