I’m really struggling trying to get anything to trigger if my nest goes into away mode. I’m only currently trying to send a pushover notification, but every time I run the configuration checker, it spits out loads of errors. If I comment out my nest away automation, it passes with success. I’ve been battling with this for days now, can anyone see where I’m going wrong?
I can see the nest under dev-tools as
climate.hallway
state:
heat
attributes:
current_temperature: 18
min_temp: 9
max_temp: 32
temperature: 12
operation_mode: heat
operation_list: off,heat,eco
away_mode: off
unit_of_measurement: °C
friendly_name: Hallway
I’m running Home Assistant from the Hassio image on a Pi3.
My config (I have changed all passwords and API credentials)
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: removed
longitude: removed
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 97
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/London
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Uncomment this to add a password (recommended!)
# api_password: PASSWORD
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
#Sensors
- platform: wunderground
api_key: 78dfhhfka98fyfjsfhakjfh
monitored_conditions:
- alerts
- precip_today_string
- temp_c
- temp_high_avg_c
- temp_low_avg_c
- weather_1d_metric
- weather_1n_metric
- weather_2d_metric
- weather_2n_metric
- weather_3d_metric
- weather_3n_metric
- platform: plex
host: my.external.plex.com
port: 32400
username: username
password: "sdhjhfjhasjdhgajhfg%NPLi&JIW"
# - platfrom: template
# are_we_home:
# entity_id: climate.hallway
# value_template: "{{ is_state_attr('climate.hallway', 'away_mode', 'on') }}"
# Text to speech
tts:
- platform: google
nest:
client_id: 5dfhjdhfd8dfjhsdjfhjsdhfksdjhf
client_secret: hfjdhfjsdhfkjsdhfkjhsdkjfh
group: !include groups.yaml
script: !include scripts.yaml
notify:
- platform: pushover
api_key: dfhkdsjfhskjdfhkjsdfhsdf
user_key: fsdjfhksjhfksdjhfkjsdhfkjsf
My automations
# Switch on lights if plex is playing - will eventually dim lights
- alias: "Test my first one"
platform: numeric_state
entity_id: sensor.thebeast
above: 0
service: light.turn_on
entity_id:
- light.kitchen_strip
# Send pushover at sunset
- id: SendPushoverAtSunset
alias: Send Pushover at Sunset
platform: sun
event: sunset
service: notify.pushover
message: "The sun has set at home."
title: "Sun Monitor"
# Send pushover is house goes into away mode
- id: NestAwayModeTestv2
alias: Testing Nest is away
platfrom: template
message: "Home has gone into away mode."
title: "Nest Monitor"
Output of hassio homeassistant check
core-ssh:/config# hassio homeassistant check
Error on homeassistant/check: starting version 3.2.2
Testing configuration at /config
2017-09-27 09:20:06 ERROR (MainThread) [homeassistant.bootstrap] Unable to setup error log /config/home-assistant.log (access denied)
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up recorder
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up http
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.0 seconds.
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up history
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up api
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up frontend
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up group
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up discovery
2017-09-27 09:20:08 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: required key not provided @ data['trigger'][0]['platform']. Got None. (See /config/configuration.yaml, line 93). Please check the docs at https://home-assistant.io/components/automation/
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up nest
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up sun
2017-09-27 09:20:08 INFO (MainThread) [homeassistant.setup] Setting up notify
2017-09-27 09:20:09 INFO (MainThread) [homeassistant.setup] Setting up sensor
2017-09-27 09:20:09 INFO (MainThread) [homeassistant.setup] Setting up updater
2017-09-27 09:20:09 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.1 seconds.
2017-09-27 09:20:09 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.1 seconds.
2017-09-27 09:20:09 INFO (MainThread) [homeassistant.setup] Setup of domain nest took 0.1 seconds.
2017-09-27 09:20:09 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
2017-09-27 09:20:09 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.1 seconds.
2017-09-27 09:20:09 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.1 seconds.
2017-09-27 09:20:09 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
message: The sun has set at home.
title: Sun Monitor
trigger: [source /config/automations.yaml:20]
platform: sun
event: sunset
- action: [source /config/automations.yaml:38]
data: [source /config/automations.yaml:40]
message: Home has gone into away mode.
title: Nest Monitor
trigger: [source /config/automations.yaml:35]
platfrom: template
value_template: {{ is_state_attr('climate.hallway', 'away_mode', 'on') }}
Successful config (partial)
automation:
- action: ?
- entity_id: ?
alias: Test my first one
hide_entity: False
trigger: ?
- platform: numeric_state
above: 0.0
entity_id: ?
- sensor.thebeast
- action: ?
- data: [source /config/automations.yaml:25]
title: Sun Monitor
hide_entity: False
trigger: ?
- platform: sun
