This automation will only trigger if the temperature is going above the target between the two hours you have defined… If the temperature is already above the target before the timeframe, this automation will not trigger when you are in the timeframe, it has to go below and than above the target again to trigger…
In fact the automation triggers and conditions are evaluated only when the trigger is becoming true and not when the trigger is true…
To be noticed, the switch will stay on (if turned on) even when you reach the “aus” time… So you have to write another automation or modify this one if you would like to switch it off at the “aus” time…
So what you have to do, in the trigger, is to add one to check that you have reached the “an” time like:
- platform: time
at: input_datetime.lufter_keller_zeit_an
and add a condition that the temperature should be above the target:
So if the temperature is going above the target or you reach the timeframe, conditions of time and temperature will be evaluated, if both are true, the switch will be turned on… but again will not be turned off at the end of the timeframe (you need a specific action/automation to do that)… Same behaviour for the switch in case of temperature going below target, it will stay on…
