Trio Lightning for you
we found a Novel lamp which we would like to buy:
https://products.trio-lighting.com/de/620010407-2/
it seems that there are some Novel lightnings compatible with Tuya (which i would not like to use anyway) but this one isn’t.
On the remote control ‘Trio lightning for you’ is written, so this seems to be the ‘remote technology’. Are there any experiences with integrating them to home assistant? also with espHome in between would be ok (as i use for some eglo lamps with an availabe esphome integration). But i did not found any specs of the remote control. lamp description only says that it is not to be used with an external dimmer…
best regards
