Trouble adding AEOTEC Z-Stick to Hass.io on RPi3
Hi all, trying to follow these instructions to connect with my z-stick:
they say:
‘To find the path of your Z-Wave USB stick or module, run:’
but none of these commands seem to be accepted by the SSH terminal, screenshot here:
the ‘grep USB’ command is accepted, as you can see, but not sure how to then determine which USB port my z-stick is plugged into.
Grateful for any help.
Thanks!
Hi all, I’ve resolved this through help from @eithe in the chat room.
The screenshot indicates that the required port is ttyACM0
