Community,
After updating the firmware on my sonoff dongle E plus from stock to ncp-uart-sw_6.10.3_115200.gbl(zigbeeFirmware/ncp-uart-sw_6.10.3_115200.gbl at edf2a0d3a717373764ec0673d4fecb0b882a636a · xsp1989/zigbeeFirmware · GitHub) and plugging it back i get some strange HA>Z2M problems. im running Zigbee2MQTT in HA on a thinclient.
About 2 or 3 light do not get the ''triggered by service ‘‘off’’ or ‘‘on’’.
to specify; im running Node-Redd to automate. so in this example: i got a Aqara motionsensor and i turn '3 table and 4 kitchen lights on when occupancy = true.
3 of 4 light turn on. the 4th one does not get the triggered by service on message.
Than the weird part; if i use MQTT message in Node-redd the light turns on just fine.
its always the same light that does not get the message, i resetted it up to 8 times and reconnected it. no luck.
so; call service trough HA = not all light receive the ‘‘on’’ message. and when i use the MQTT message in node redd the light gets the ‘‘on and off message’’ just fine.
tried to reinstall the broker and Z2M, rebooted the whole system 3x. rebooted HA 3x. no luck so far.
its just the node-redd flow trigger that does not work after the dongle update. in my dashboard the light toggle works fine. also in Zigbee2MQTT the toggle works just fine. only the flow does not trigger the light, i also tried to make a different flow with no luck.
this flow works just fine after the update.
how is the communication so broken? what intergration to reload or what could fix it.
