I have a keypad that I use to trigger various things, and now I want to assign a key to call a web service to close a door.
I’ve searched, and using rest_command seems to be the recommended approach, but it’s failing.
In configuration.yaml, I added:
rest_command:
office_door_close:
url: "http://192.168.0.226:8000/srvc?target=closed"
office_door_open:
url: "http://192.168.0.226:8000/srvc?target=open"
I created an automation, then edited automation.yaml:
- id: '1735321750276'
alias: NewCloseDoor
description: Close the door when keypad "+" is pressed
- platform: event
event_type: keyboard_remote_command_received
event_data:
key_code: 78
type: key_down
device_descriptor: /dev/input/event0
condition: []
- service: rest_command.close_office_door
data: {}
mode: single
When I press the key, the automation is triggered, but it generates this error:
The automation “NewCloseDoor” (
automation.newclosedoor_2
) has an action that calls an unknown service:rest_command.close_office_door
.This error prevents the automation from running correctly. Maybe this service is no longer available, or perhaps a typo caused it.
To fix this error, edit the automation and remove the action that calls this service.
Click on SUBMIT below to confirm you have fixed this automation.
I have tried some changes, like adding an explicit method for the web service.
I’d appreciate help, including changing away from using rest_command
if there’s a better way.
