Trouble Commissioning Matter Device w/ SkyConnect
I have an Eve Energy Outlet that is running the Beta firmware that supports Matter.
I was able to add the outlet to Apple Homekit without any issues, when attempting to pair the device with Home Assistant I am unsuccessful.
I have Home Assistant running on a Raspberry Pi 3b and using the SkyConnect usb Zigbee & Thread dongle available directly from Home Assistant. I have enabled multiprotocol support on the device also.
When attempting to add the device to Home Assistant I get the following errors in the Matter Server logs. Does anyone have any idea what is going on, I am not familiar with the intricacies of Matter and Thread.
The only thing I do notice is the log is referring to eth0 however my Home Assistant is using Wifi not ethernet.
2023-03-15 11:53:35 core-matter-server chip.DIS[126] DEBUG SRV record already actively processed.
2023-03-15 11:53:35 core-matter-server chip.DIS[126] DEBUG Warning: Attempt to mDNS broadcast failed on eth0:  ../src/inet/UDPEndPointImplSockets.cpp:411: OS Error 0x02000065: Network is unreachable
2023-03-15 11:53:35 core-matter-server chip.DIS[126] DEBUG mDNS broadcast had only partial success: 25 successes and 1 failures.
2023-03-15 11:53:39 core-matter-server chip.DIS[126] DEBUG SRV record already actively processed.
2023-03-15 11:53:39 core-matter-server chip.DIS[126] DEBUG Warning: Attempt to mDNS broadcast failed on eth0:  ../src/inet/UDPEndPointImplSockets.cpp:411: OS Error 0x02000065: Network is unreachable
2023-03-15 11:53:39 core-matter-server chip.DIS[126] DEBUG mDNS broadcast had only partial success: 25 successes and 1 failures.
Bumping this thread - I also have a SkyConnect on my HA Blue, running the Silicon Labs Multiprotocol. I recently bought some Nanoleaf bulbs and 3 of the Aqara Door and Window Sensor P2’s.
I added one of the Nanoleaf Bulbs, and the first of the Aqara P2’s successfully, and can see them in HA, but when I try to add the remaining 2 Aqara P2’s, the commissioning on my Android Device times out and the Matter debug logs show the SRV record error. I do not see the eth0 errors the OP posts, as I have my HA using the eth0 as its primary network interface.
+1 on the “SRV record already actively processed” error. I have added one Eve Energy plug (already in homekit, then added to HA). I’m trying to do the same thing with a second plug, and everytime I begin to pair (commission) the second plug I see dozens of the “SRV record already actively processed” in the logs and an “unable to add accessory” shortly after.
I first thought my network topology was the issue (and still may be!), but it’s strange I was able to add one plug and not another.
On version : 4.9.0 of the matter addon.
