I want to be able to use the built-in SK6812 (single) LED on the Atom Lite as a sort of “status light”, while the LED Strip will be used as the lamp element. I also have the built-in button working on GPIO39.
Here is the YAML that works with just the “status light”:
As mentioned, this works exactly as you might expect.
Once I connect the PbHUB to the GROVE connector on the Atom Lite, and then plug the LED Strip into the hub (channel 3)… shenanigans ensue…
The “status light” that should turn on, red, on boot, does not turn on at boot
The “Built-in LED” entity in Home Assistant shows “on” and “red”, even though the light is not actually on.
The “Pb.HUB LED Strip” entity in Home Assistant controls the built-in LED, but not the LED strip.
Meaning, even though the “Built-in LED” entity does not control the onboard LED, changing the state, color, or brightness of the “Pb.HUB LED Strip” entity in Home Assistant does control the built-in LED.
I’ve scoured the documentation for both the PbHUB and the LED strip, but cannot, for the life of me, figure out what I’m doing wrong. I found one post on the m5stack forums that involved the PbHUB, but that person was connecting sensors and using the “address” mapping for the sensors. NeoPixel does not accept “address” as an option.
Here is the YAML code with my attempts to configure the LED strip.
esphome:
friendly_name: [Friendly Name]
area: [area]
on_boot:
then:
- light.turn_on:
brightness: 25%
red: 100%
green: 0%
blue: 0%
esp32:
board: esp32dev
framework:
type: Arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: {encryption key}
ota:
password: {ota password}
wifi:
ssid: !secret wifi_ssid
fast_connect: true
ap:
ssid: {something}
password: {something}
captive_portal:
i2c:
sda: 21
scl: 22
scan: True
light:
- platform: neopixelbus
pin: GPIO27
num_leds: 1
variant: SK6812
entity_category: diagnostic
name: Pb.HUB LED Strip
# all of these PIN options are commented out solely for the purposes of sharing the code. I've tried all of these.
# pin: 19 # Channel 3 on the Pb.HUB ?
# pin: GPIO21 # from the m5stack documentation for the LED strip
# pin: GPIO27 # Same GPIO as the built-in LED
variant: SK6812
num_leds: 29
effects:
- addressable_rainbow:
- addressable_color_wipe:
- addressable_scan:
- addressable_twinkle:
binary_sensor:
- platform: gpio
pin:
number: GPIO39
inverted: true
I’ve made some incremental progress. With the LED Strip connected directly to the GROVE port on the Atom Lite, this modified light block works as intended. I’m going to try this with the LED Strip connected to the PbHUB next.
So, while trying to get the LED strip to work on the PbHUB, I somehow broke everything, which I guess is an expected part of this process. I ended up finding someone, though, that’s already written a custom component for the PbHUB and ESPHome: Chill-Division (GitHub).
Using this custom component, I was able to get the M5Stack Dual Button that I also want to use working while connected to the PbHUB. I’m working on incorporating the LED strip at this point, but running into an issue where the light config for the LED strip doesn’t like the pin configuration I’ve written. I get This variable only supports pin numbers, not full pin schemas (with inverted and mode). on the pin: > number: 30 line (line 117).
esphome:
friendly_name: {something}
area: {something}
libraries:
- Wire
on_boot:
then:
- light.turn_on:
brightness: 30%
red: 100%
green: 0%
blue: 0%
- light.turn_on:
brightness: 30%
red: 50%
green: 0%
blue: 50%
esp32:
board: m5stack-atom
framework:
type: arduino
# Enable logging
logger:
level: VERY_VERBOSE
api:
encryption:
key: {something}
ota:
wifi:
fast_connect: true
ap:
ssid: {something}
captive_portal:
# Disabling I2C for now since the PbHUB is using the same pins
#i2c:
# sda: 26 # grove connector, per https://docs.m5stack.com/en/core/atom_lite
# scl: 32 # grove connector, per https://docs.m5stack.com/en/core/atom_lite
# id: grove
# frequency: 400 kHz
# scan: true
spi:
clk_pin: 23 # per https://docs.m5stack.com/en/core/atom_lite
mosi_pin: 19 # per https://docs.m5stack.com/en/core/atom_lite
miso_pin: 33 # per https://docs.m5stack.com/en/core/atom_lite
# Custom component for the M5Stack Pb.HUB
external_components:
- source:
type: git
url: https://github.com/chill-Division/M5Stack-ESPHome/
ref: main
components: m5stack_pbhub
# Pin numberring in the PbHUB (The first digit is the channel number and the second digit is the pin number)
# CHANNEL 0 : 00 and 01
# CHANNEL 1 : 10 and 11
# CHANNEL 2 : 20 and 21
# CHANNEL 3 : 30 and 31
# CHANNEL 4 : 40 and 41
# CHANNEL 5 : 50 and 51
# M5Stack PbHUB device configuration
m5stack_pbhub:
- id: 'M5Stack_HUB'
address: 0x61 # Base I2C Address
sda: 26 # I2C SDA Pin (Yellow grove cable)
scl: 32 # I2C SCL Pin (White grove cable)
light:
# Built-in RGB LED (SK6812) on GPIO27
- platform: esp32_rmt_led_strip
pin: GPIO27
default_transition_length: 0s
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
effects:
- pulse:
transition_length: 250ms
update_interval: 250ms
# M5Stack RGB LED Strip (SK6812) on Pb.HUB Ch 3
# pin: GPIO26 # from the grove port
# pin: GPIO32 # grove i2c
# pin: GPIO25 # i2c data pin 25
# pin: GPIO21 # works with scl 21 / sda 25 WITHOUT the built-in led configured; does not work when built-in led is configured
# pin: GPIO23 # google bard conversation
pin:
m5stack_pbhub: M5Stack_HUB
# Use channel 3, pin number 0
number: 30 # error: This variable only supports pin numbers, not full pin schemas (with inverted and mode)
mode:
output: true
variant: SK6812
num_leds: 29
effects:
- addressable_scan:
binary_sensor:
# Built-in button on GPIO39
- platform: gpio
pin:
number: GPIO39
inverted: true
# M5Stack Dual Button on Pb.HUB Ch 5, red button
- platform: gpio
pin:
# Use channel 5, pin number 0
number: 50
mode:
output: true
inverted: true
# M5Stack Dual Button on Pb.HUB Ch 5, blue button
- platform: gpio
pin:
# Use channel 5, pin number 1
number: 51
mode:
output: true
inverted: true
