I am running HA and InfluxDB in Docker on a Synology.
Both containers run without any problem but getting HA to write its sensor data into a bucket on InfluxDB does not work.
I am running:
Home Assistant 2023.1.7
InfluxDB v2.6.1
I startet of with a configuration like this
influxdb:
host: 192.168.1.110
port: !secret influx_port
database: home_assistant
username: !secret influx_username
password: !secret influx_password
and got the error message:
InfluxDB database is not accessible due to ā401: {ācodeā:āunauthorizedā,āmessageā:āUnauthorizedā}ā. Please check that the database, username and password are correct and that the specified user has the correct permissions set.
Trying to fix the issue I changed the configuration to the following, because of the version number of InfluxDB (2.6.1):
influxdb:
host: 192.168.1.110
api_version: 2
port: 8086
organization: !secret influx_organization
token: !secret influx_token
Organization is the id found on InfluxDB, the same goes for the token, which is the token for the bucket I want to write to.
When checking the configuration in HA the config will not prevent HA from startingā¦ however, now the logs show this error:
Logger: homeassistant.setup
Source: components/influxdb/__init__.py:365
First occurred: 11:19:19 (1 occurrences)
Last logged: 11:19:19
Error during setup of component influxdb
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 1042, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 414, in connect
self.sock = ssl_wrap_socket(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/ssl_.py", line 453, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(sock, context, tls_in_tls)
File "/usr/local/lib/python3.10/site-packages/urllib3/util/ssl_.py", line 495, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock)
File "/usr/local/lib/python3.10/ssl.py", line 513, in wrap_socket
return self.sslsocket_class._create(
File "/usr/local/lib/python3.10/ssl.py", line 1071, in _create
self.do_handshake()
File "/usr/local/lib/python3.10/ssl.py", line 1342, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:997)
File "/usr/local/lib/python3.10/site-packages/influxdb_client/rest.py", line 217, in request
r = self.pool_manager.request(
File "/usr/local/lib/python3.10/site-packages/urllib3/request.py", line 78, in request
return self.request_encode_body(
File "/usr/local/lib/python3.10/site-packages/urllib3/request.py", line 170, in request_encode_body
return self.urlopen(method, url, **extra_kw)
File "/usr/local/lib/python3.10/site-packages/urllib3/poolmanager.py", line 376, in urlopen
response = conn.urlopen(method, u.request_uri, **kw)
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 787, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/retry.py", line 525, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.10/site-packages/urllib3/packages/six.py", line 769, in reraise
raise value.with_traceback(tb)
conn.connect()
self.do_handshake()
urllib3.exceptions.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:997)
File "/usr/src/homeassistant/homeassistant/setup.py", line 253, in _async_setup_component
result = await task
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 486, in setup
influx = get_influx_connection(conf, test_write=True)
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 393, in get_influx_connection
write_v2(b"")
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 365, in write_v2
write_api.write(**data)
File "/usr/local/lib/python3.10/site-packages/influxdb_client/client/write_api.py", line 371, in write
results = list(map(write_payload, payloads.items()))
File "/usr/local/lib/python3.10/site-packages/influxdb_client/client/write_api.py", line 369, in write_payload
return self._post_write(_async_req, bucket, org, final_string, payload[0])
File "/usr/local/lib/python3.10/site-packages/influxdb_client/client/write_api.py", line 517, in _post_write
return self._write_service.post_write(org=org, bucket=bucket, body=body, precision=precision,
File "/usr/local/lib/python3.10/site-packages/influxdb_client/service/write_service.py", line 62, in post_write
(data) = self.post_write_with_http_info(org, bucket, body, **kwargs) # noqa: E501
File "/usr/local/lib/python3.10/site-packages/influxdb_client/service/write_service.py", line 166, in post_write_with_http_info
return self.api_client.call_api(
File "/usr/local/lib/python3.10/site-packages/influxdb_client/api_client.py", line 341, in call_api
return self.__call_api(resource_path, method,
File "/usr/local/lib/python3.10/site-packages/influxdb_client/api_client.py", line 171, in __call_api
response_data = self.request(
File "/usr/local/lib/python3.10/site-packages/influxdb_client/api_client.py", line 386, in request
return self.rest_client.POST(url,
File "/usr/local/lib/python3.10/site-packages/influxdb_client/rest.py", line 304, in POST
return self.request("POST", url,
File "/usr/local/lib/python3.10/site-packages/influxdb_client/rest.py", line 240, in request
raise ApiException(status=0, reason=msg)
File "/usr/local/lib/python3.10/site-packages/influxdb_client/rest.py", line 360, in __init__
super().__init__(response=http_resp)
File "/usr/local/lib/python3.10/site-packages/influxdb_client/client/exceptions.py", line 16, in __init__
self.message = self._get_message(response)
File "/usr/local/lib/python3.10/site-packages/influxdb_client/client/exceptions.py", line 22, in _get_message
if response.data:
AttributeError: 'NoneType' object has no attribute 'data'
Any help here is appreciated! How can I get HA to access the InfluxDB bucket and write the sensor data into it?
