Trouble connecting Esp8266 with MQTT
I’m new to home assistant, but I’ve been playing around with Arduino / ESP8266 for a couple years now.
I am trying to use MQTT to toggle On/Off a led on the Esp8266.
It seems like I’m having trouble connecting to the Mosquitto broker.
This is the sketch I am using to connect
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const char* _SSID = "Phantom";
const char* _Password = "**************";
const char* mqtt_server = "192.168.0.16";
const char* mqtt_user = "MQTT";
const char* mqtt_password = "**********";
WiFiClient espClient;
PubSubClient client(espClient);
void callback(char* topic, byte* payload, unsigned int length)
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++)
    Serial.print((char)payload[i]);
  Serial.println();
  // Switch on the LED if an 1 was received as first character
  if ((char)payload[0] == '1')
    digitalWrite(LED_BUILTIN, LOW);   // Turn the LED on (Note that LOW is the voltage level
    // but actually the LED is on; this is because
    // it is active low on the ESP-01)
  } else
    digitalWrite(LED_BUILTIN, HIGH);  // Turn the LED off by making the voltage HIGH
void setup_wifi()
  // We start by connecting to a WiFi network
  Serial.println();
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(_SSID);
  WiFi.mode(WIFI_STA);
  WiFi.begin(_SSID, _Password);
  while (WiFi.status() != WL_CONNECTED)
    delay(500);
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void reconnect()
  // Loop until we're reconnected
  while (!client.connected())
    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP8266Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
    if (client.connect(clientId.c_str()), mqtt_user, mqtt_password)
      Serial.println("connected");
      // Once connected, publish an announcement...
      client.publish("outTopic", "hello world");
      // ... and resubscribe
      client.subscribe("inTopic");
    } else
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void setup()
  Serial.begin(115200);
  setup_wifi();
  pinMode(LED_BUILTIN, OUTPUT);    // Initialize the LED_BUILTIN pin as an output
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
void loop()
  if (!client.connected())
    reconnect();
  client.loop();
My Serial monitor is spamming the message
Attempting MQTT connection…connected
meaning it’s passing the line if (client.connect(clientId.c_str()), mqtt_user, mqtt_password)
but then in the main loop client.connected() returns false and try to reconnect every iteration of the loop
Also If I check the logs from Mosquitto I can see this error message:
2022-10-15 16:48:03: New connection from 192.168.0.184:58658 on port 1883.
error: received null username or password for unpwd check
My MQTT user looks like this:
And my my configuration file looks like this:
# Loads default set of integrations. Do not remove.
default_config:
# MQTT broker
mqtt:
  light:
    - name: "EspLight"
      command_topic: "home/ESPTest/light"
      state_topic: "home/ESPTest/status"
      payload_on: "0"
      payload_off: "1"
      retain: true
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
Anyone able to help? I am running out of ideas…
Turns out I was able to make it work using a different way of declaring the client and connecting in the code.
The mqtt_esp8266 example doesn’t work, but the one in mqtt_auth example does work.
basically had to declare the client like so:
IPAddress server(192, 168, 0, xxx);
PubSubClient client(server, 1883, callback, espClient);
and call the connect method in the setup()
client.connect("arduinoClient", mqtt_user, mqtt_password)
