Trouble connecting ip camera with generic ip cam extension
Hi Guys,
I have a smartware IP camera that i am trying to connect to Home Assistant.
First I opened VLC and verified that I can stream the output with following url rtsp://IP:554/live/av0?user=admin&passwd=PASSWORD.
After that I tried the following config in HA, but no matter which options I try I get a authentication failure.
How can I found out if i need the Generic IP Camera or the Generic MJPEG IP Camera integration?
still_image_url is required for the generic IP camera but I don’t know if my camera has that feature
camera:
    - platform: generic
      still_image_url: rtsp://192.168.0.149:554/live/av0
      stream_source: rtsp://192.168.0.149:554/live/av0
      username: admin
      password: PASS
      verify_ssl: False
Hello Levent,
I have exactly the same issue, were you able to find a solution somehow?
