Hi All, my Hassio (HASSOS?) install got corrupted. It was running on a Pi 3B+ and USB SSD.
I have since reinstalled it on another USB SSD and decided to prep the USB SSD with the failed installation of Hassio by burning the latest HassOS to it.
balenaEtcher failed to “burn” the new image on the USB so I tried to first format the USB SSD on my Mac. This also fails. (I have to “initialise…” the drive before it is seen by the Mac/balenaEtcher.)
What I can see happening is that the drive gets unmounted in the format process and then fails because the initialise message pops up again.
I can see all the volumes/partitions that is created on the USB SSD but cannot resize/delete any of them.
Finally I tried to format it from a Pi 3B running the latest raspberry os. This also fails but at least I got more info.
mke2fs 1.44.5 (15-Dec-2018)
/dev/sda1 contains a vfat file system labelled 'hassos-boot'
Proceed anyway? (y,N) y
Creating filesystem with 32768 1k blocks and 8192 inodes
Filesystem UUID: bla...bla
Superblock backups stored on blocks:
8193, 24577
Allocating group tables: done
Writing inode tables: done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: mkfs.ext4: Input/output error while writing out and closing file system
Am I missing something?
It is a Sandisk extreme Pro which is not that old, so I don’t think the drive itself is faulty.
Thanks again for the help! (Not sure why my searches did not find me this link…)
The USB SSD disc is still ignoring me…
PBMBP2015:Downloads paulburger$ sudo dd if=/dev/zero of=/dev/disk3 bs=1m count=1
1+0 records in
1+0 records out
1048576 bytes transferred in 2.421670 secs (432997 bytes/sec)
Afterwards (ejecting and then re-inserting + initialise to see it) it looks identical to before.
/dev/disk3 (external, physical):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *128.0 GB disk3
1: Microsoft Reserved 33.6 MB disk3s1
2: Linux Filesystem 25.2 MB disk3s2
3: Linux Filesystem 268.4 MB disk3s3
4: Linux Filesystem 25.2 MB disk3s4
5: Linux Filesystem 268.4 MB disk3s5
6: Linux Filesystem 8.4 MB disk3s6
7: Linux Filesystem 100.7 MB disk3s7
8: Linux Filesystem 127.3 GB disk3s8
I have removed the current SSD (first one below) from HA and it looks identical to the one I’m trying to format (second one below).
I’m too scared to try and format the one that is working in case I “break” that one too and then I have no more HA (as it is just not worth using off an SD Card).
Command (m for help): p
Disk /dev/sda: 119.3 GiB, 128043712512 bytes, 250085376 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 67583 65536 32M c W95 FAT32 (LBA)
/dev/sda2 1 2047 2047 1023.5K ee GPT
Partition table entries are not in disk order.
Command (m for help): M
Leaving nested disklabel.
Disk model: Extreme Pro
Disklabel type: gpt
Disk identifier: C63FDEBF-E0F2-4EE3-88F9-B7B862988B03
Device Start End Sectors Size Type
/dev/sda1 2048 67583 65536 32M Microsoft reserved
/dev/sda2 67584 116735 49152 24M Linux filesystem
/dev/sda3 116736 641023 524288 256M Linux filesystem
/dev/sda4 641024 690175 49152 24M Linux filesystem
/dev/sda5 690176 1214463 524288 256M Linux filesystem
/dev/sda6 1214464 1230847 16384 8M Linux filesystem
/dev/sda7 1230848 1427455 196608 96M Linux filesystem
/dev/sda8 1427456 250085342 248657887 118.6G Linux filesystem
Command (m for help): q
pi@raspberrypi:~ $ sudo fdisk /dev/sda
Welcome to fdisk (util-linux 2.33.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
A hybrid GPT was detected. You have to sync the hybrid MBR manually (expert command 'M').
Entering protective/hybrid MBR disklabel.
Disklabel type: dos
Disklabel type: gpt
Disk identifier: 631DE6C9-97D2-45FF-9279-F20BFCB7AB4A
I’m assuming the fact that the file write of the wipe command did not succeed as the one for PMBR only displays two hex(?) values.
Disklabel type: gpt
pi@raspberrypi:~ $ sudo wipefs -a -f /dev/sda
/dev/sda: 8 bytes were erased at offset 0x00000200 (gpt): 45 46 49 20 50 41 52 54
/dev/sda: 8 bytes were erased at offset 0x1dcffffe00 (gpt): 45 46 49 20 50 41 52 54
/dev/sda: 2 bytes were erased at offset 0x000001fe (PMBR): 55 aa
pi@raspberrypi:~ $ sudo fdisk -l
Disklabel type: gpt
Anyway, it seems I need to go and buy another SDD but also do not really want to go down this route if it will simply happen again when the pi 4b+ comes out.
I know Diskpart works…do you have a friend with a windows computer? It is possible that the ssd has failed, but most likely it’s a problem with the partition table or something on the drive itself which can be repaired with diskpart or equivalent…
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 64 GB 0 B
Disk 1 Online 119 GB 119 GB
DISKPART> select disk 1
Disk 1 is now the selected disk.
DISKPART> clean
DiskPart has encountered an error: Data error (cyclic redundancy check).
See the System Event Log for more information.
DISKPART>
I found these steps and will be trying those this evening.
I finally got to try AOMEI partition assistant and from what I can see is that there are 4 bad sectors on the usb stick.
The problem now is that AOMEI uses chkdsk to mark the bad sectors, but because I have wiped the disc the it can not be mounted, which means the t option is greyed out. I first need to create a partition, however the bad sectors is preventing AOMEI from creating the partitions.
I’m sure it must be possible to recover/reformat the disc, but I’m giving up and will wait for the Argon M.2 case which should hopefully be stable in the long run.
