Hey i’m trying to get the H801 led controller working, but the light bulb in the interface is not chaning color, how can i solve this isue?
platform: mqtt
name: “Woonkamer RGB Snoer”
state_topic: “stat/Woonkamer/RgbSnoer/POWER”
command_topic: “cmnd/Woonkamer/RgbSnoer/POWER”brightness_state_topic: “stat/Woonkamer/RgbSnoer/Dimmer”
brightness_command_topic: “cmnd/Woonkamer/RgbSnoer/Dimmer”
brightness_value_template: “{{ value_json.Dimmer }}”
brightness_scale: 100rgb_command_template: “{{ ‘#%02x%02x%02x%02x%02x’ | format(green, red, blue, 00, 00)}}”
rgb_command_topic: “cmnd/Woonkamer/RgbSnoer/Color2”
rgb_state_topic: “stat/Woonkamer/RgbSnoer/Color2”
rgb_command_mode: hex
rgb_value_template: “{% if value_json.Color2 is defined %}{{ value_json.Color2[0:2]|int(base=16) }},{{ value_json.Color2[2:4]|int(base=16) }},{{ value_json.Color2[4:6]|int(base=16) }}{% else %}{{ states.light.Woonkamer_rgb_snoer.attributes.COLOR2|join(’,’) }}{% endif %}”color_temp_command_topic: “cmnd/Woonkamer/RgbSnoer/CT”
effect_command_topic: “cmnd/Woonkamer/RgbSnoer/SCHEME”
effect_state_topic: “stat/KWoonkamer/RgbSnoer/RESULT”
effect_value_template: “{% if value_json.Scheme is defined %}{{ value_json.Scheme }}{% else %}{{ states.light.woonkamer_rgb_snoer.attributes.effect }}{% endif %}”
effect_list:- 0
- 1
- 2
- 3
- 4
qos: 0
payload_on: “ON”
payload_off: “OFF”
optimistic: false
