Trouble integratings a Razberry-board (HASSio and HA Supervisor is installed in a Docker container)
I just installed a razberry-board and when I go to check hardware in HA, it shows:
serial:
/dev/ttyS0
/dev/ttyAMA0
My guess is that HA recognizes the board but I’m not certain. If I click on “configuration” I don’t see anything that says, Z-Wave, so I don’t think I can add a Z-wave device. (Can I?).
I have the supervisor version of HASSio / HA from here: https://raw.githubusercontent.com/Kanga-Who/home-assistant/master/supervised-installer.sh" (I installed using the instructions here: Installing Home Assistant Supervised on Raspberry Pi OS) and it’s installed on a Docker container.
Can anyone please help me get HA to recognize it?
UPDATE: I already followed the steps to disable the internal bluetooth, is that as listed here: https://www.home-assistant.io/docs/z-wave/device-specific/#razberry-board. Is that still necessary if my HA is in a docker container?
Thanks!
From configurations click integrations, then the plus sign to add z-wave.
Thanks! I got it working. I’m assuming that I still have to have bluetooth disabled, is that correct?
I have no idea.
