Running 68.1 on Ubuntu 18. I don’t get any frontend errors but it never loads completely. The only message I see show up in the log is this. Any ideas?
May 10 22:01:47 home-assistant hass[16745]: 2018-05-10 22:01:47 INFO (MainThread) [homeassistant.loader] Loaded switch.broadlink from homeassistant.components.switch.broadlink
May 10 22:01:48 home-assistant hass[16745]: 2018-05-10 22:01:48 INFO (MainThread) [homeassistant.components.switch] Setting up switch.broadlink
May 10 22:01:48 home-assistant hass[16745]: 2018-05-10 22:01:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=broadlink_learn_command_172_20_14_44>
May 10 22:01:48 home-assistant hass[16745]: 2018-05-10 22:01:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=broadlink_send_packet_172_20_14_44>
2018-05-10 21:56:24 DEBUG (SyncWorker_0) [homeassistant.util.json] JSON file not found: /srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/switch/.translations/broadlink.en.json
