Trouble logging in on iOS app
Hi. Trying to add my hass install to the iOS app, but every time I try logging in I get the connection error on the picture.
I don’t know what I’m doing wrong so any help is much appreciated
Per
I also can’t login. This is actually a very weird login screen that asks only a password and no username.
The current app only supports the old legacy api_password which does not have a username. A new version of the app is in beta that will support the username/password option. (and I think 2FA).
Thanks for the heads up! Is there a way to get a legacy password on the current version of Hassio?
Do you have port 8123 as a port forward on your router?
Also, as it appears you are connected to WiFi, are you connected to your home WiFi? If so does your router support hairpin NAT/loopback? Try turning off WiFi and see if it works, we can troubleshoot from there.
Disabling WiFi did the trick.
Thank you
thanks!!!
