I am trying to migrate an existing SML Setup from Tasmota to ESPHome.
So far no output from SML component but this is to be expected when reading the debug output from UART.
This is what I use in my esp8266 Tasmota Script:
+1,14,s,16,9600,SML1
So it is a SML input on GPIO14 with 9600 baud rate.
I tried to replicate the same in esphome
uart:
- id: uart_bus1
rx_pin:
number: GPIO14 #
inverted: false
baud_rate: 9600
data_bits: 8
parity: NONE
stop_bits: 1
debug:
sml:
- id: sml1
uart_id: uart_bus1
The ESPHome debug output looks very odd
[09:02:48.983][D][uart_debug:114]: <<< 12:12:12:12:00:00:00:00:64:00:00:1C:78:08:40:00:40:00:60:42:00:00:64:00:06:FE:FE:FE:FE:FE:FE:00:00:9E:7E:10:02:00:00:08:06:10:00:00:3C:72:00:60:40:00:40:00:9E:7E:32:00:42:30:06:00:64:00:00:1C:78:08:40:00:40:00:60:42:06:00:66:06:FE:FE:FE:FE:FE:FE:02:00:00:08:06:10:00:00:3C:72:00:06:00:00:40:00:FE:FE:60:40:00:40:00:9E:7E:32:60:66:06:00:00:40:20:00:00:00:00:00:00:00:08:06:10:00:66:06:00:00:40:00:00:FE:00:00:00:00:02:00:00:08:06:10:00:00:3C:72:00:00
[09:02:49.190][D][uart_debug:114]: <<< 66:06:00:00:00:00:00:FE:40:00:18:40:00:60:40:00:40:00:9E:7E:32:40:1C:00:FE:40:00:00:00:00:00:00:1C:1C:00:66:06:00:00:00:00:00:FE:00:60:40:00:40:00:9E:7E:32:40:1C:00:FE:40:00:00:00:00:00:80:20:00:00:66:06:00:00:00:06:00:FF:00:00:40:12:00:00:10:00:00:00:00:00:00:00:00:00:00:00:42:84:12:00:64:00:00:1C:78:0C:40:00:40:00:60:42:00:00:60:00:42:00:0C:00:00:00:12:12:12:12:10:00:F0:70
compared to the Tasmota (sensor53 d1)
16:49:18.859 : 77 07 01 00 60 32 01 01 01 01 01 01 04 4c 47 5a 01
16:49:18.860 : 77 07 01 00 60 01 00 ff 01 01 01 01 0b 0a 01 4c 47 5a 00 04 3e 7b 01 01
16:49:18.911 : 77 07 01 00 01 08 00 ff 65 00 1c 33 04 72 62 01 65 00 df fa c9 62 1e 52 ff 69 00 00 00 00 00 24 43 89 01
16:49:18.961 : 77 07 01 00 02 08 00 ff 01 72 62 01 65 00 df fa c9 62 1e 52 ff 69 00 00 00 00 02 d2 b5 4b 01
16:49:19.809 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 59 00 00 00 00 00 00 00 05 01 01 01 63 ee 60 00 76 05 02 9f ef f8 62 00 62 00
16:49:19.811 : 77 07 ff ff ff ff ff ff 0b XX XX XX XX XX XX XX XX XX XX 07 01 00 62 0a ff ff 72 62 01 65 00 df fa ca 75
I redacted the Meter Serial.
I tried inverting the UART port pin, only looks different after that:
12:10:18.625][D][uart_debug:114]: <<< 7F:23:27:7F:4D:82:2A:31:27:38:2B:00:4B:FE:FE:FE:F6:B6:27:19:7F:44:7C:7F:BE:E2:FE:02:7F:7F:27:72:2B:9A:FE:FE:FE:FE:FE:FE:FE:B6:FA:FA:FA:72:A6:0E:FC:26:EA:F6:82:F4:D2:76:FE:76:FE:36:72:F6:FA:3A:FA:72:82:2E:FE:FE:92:92:92:92:96:F6:36:3E:00
[12:10:19.475][D][uart_debug:114]: <<< 72:72:92:FA:FA:FA:26:F6:F4:CE:F2:B6:D2:D9:7C:00:00:00:00:00:00:FE:48:4E:3D:7F:5C:29:30:FD:D9:42:62:72:A2:0C:A4:3F:FD:CA:F2:F2:36:72:E2:FA:22:E2:02:04:20:00:7A:3D:7F:5C:29:30:FD:FA:FE:76:D6:02:00:23:27:7F:4D:82:2A:62:45:44:7C:7F:7E:36:FA:FA:FA:FA:FA:FA:EE:CE:E2:96:FA:22:E2:FA:FE:7E:FA:FE:02:7F:7F:7F:7F:7A:3D:7F:96:59:F9:EE:06:12:FA:FA:22:E2:FA:FE:FA:DE:FE:02:4D:8E:7A:EE:36:76:FA:6A:FE:82:2A:62:27:38:2B:00:4B:FE:FE:FE:FE:6E:FE:4E:7F:44:7C:7F:F6:DE
[12:10:19.623][D][uart_debug:114]: <<< FE:02:7F:23:27:7F:4D:82:2A:62:27:38:2B:00:4B:FE:FE:FE:F6:B6:27:19:7F:44:7C:7F:BE:E2:FE:02:7F:7F:27:72:2B:9A:FE:FE:FE:FE:FE:FE:FE:FE:FA:FA:FA:72:52:42:FC:26:EA:F6:82:F4:C6:76:FE:76:FE:36:72:F6:FA:3A:FA:72:92:CA:FE:FE:FE:92:92:92:92:96:F6:AA:00
[12:10:20.472][D][uart_debug:114]: <<< 92:92:FA:FA:FA:FA:26:EA:82:D9:F2:76:B6:D2:22:F1:02:02:02:EA:82:B1:D2:D6:FA:CE:E2:F9:EE:93:36:E9:F2:84:7F:62:96:FE:52:82:BE:76:FE:76:FE:92:12:FA:12:80:01:03:D8:D6:FA:CE:EF:9F:FF:E2:FE:76:D6:02:00:23:27:7F:4D:82:2A:98:91:24:FA:FE:7E:36:FA:FA:FA:FA:FA:FA:EE:CE:E2:96:FA:22:E2:FA:FE:7E:FA:FE:02:7F:7F:7F:7F:7A:3D:7F:96:59:F9:EE:06:12:FA:FA:22:E2:FA:FE:FA:DE:FE:02:4D:8E:5A:EE:36:76:FA:6A:FE:82:2A:98:27:38:2B:00:4B:FE:FE:FE:FE:6E:FE:4E:7F:44:7C:7F:F6:DE
[12:10:20.624][D][uart_debug:114]: <<< FE:02:7F:23:27:7F:4D:82:2A:98:27:38:2B:00:4B:FE:FE:FE:F6:B6:27:19:7F:44:7C:7F:BE:E2:FE:02:7F:7F:27:72:2B:9A:02:00:00:00:00:00:00:06:7F:7F:7F:4E:24:72:26:EA:F6:82:F4:BA:76:FE:76:FE:36:72:F6:FA:3A:FA:72:B6:7E:FE:FE:FE:92:92:92:92:96:F6:DA:33
Any ideas where I am doing a mistake here?
Would think the very same hardware should rule this out, but it is a different NodeMCU esp8266 module…
Are the defaults for the serial port ( like 9600 bits/sec, No Parity, 1 Stop bit different in Tasmota and ESPHome?.
