Trying to setup mint-scraper-for-homeassistant but getting an error when it attempts to initialize. Hoping to get some help. This is my first appdaemon.
2023-11-13 16:47:39.194721 INFO AppDaemon: AppDaemon Version 4.4.2 starting
2023-11-13 16:47:39.194886 INFO AppDaemon: Python version is 3.11.6
2023-11-13 16:47:39.195002 INFO AppDaemon: Configuration read from: /config/appdaemon/appdaemon.yaml
2023-11-13 16:47:39.195123 INFO AppDaemon: Added log: AppDaemon
2023-11-13 16:47:39.195226 INFO AppDaemon: Added log: Error
2023-11-13 16:47:39.195306 INFO AppDaemon: Added log: Access
2023-11-13 16:47:39.195390 INFO AppDaemon: Added log: Diag
2023-11-13 16:47:39.280970 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2023-11-13 16:47:39.447092 INFO HASS: HASS Plugin Initializing
2023-11-13 16:47:39.447221 INFO HASS: HASS Plugin initialization complete
2023-11-13 16:47:39.447338 INFO AppDaemon: Loading Plugin MQTT using class MqttPlugin from module mqttplugin
2023-11-13 16:47:39.479503 INFO MQTT: MQTT Plugin Initializing
2023-11-13 16:47:39.479853 INFO MQTT: Using 'appdaemon_client/status' as Will Topic
2023-11-13 16:47:39.479934 INFO MQTT: Using 'appdaemon_client/status' as Birth Topic
2023-11-13 16:47:39.480054 WARNING AppDaemon: error loading plugin: MQTT - ignoring
2023-11-13 16:47:39.480125 WARNING AppDaemon: ------------------------------------------------------------
2023-11-13 16:47:39.480665 WARNING AppDaemon: Traceback (most recent call last):
File "/usr/lib/python3.11/site-packages/appdaemon/plugin_management.py", line 149, in __init__
raise ValueError("Duplicate namespace: {}".format(namespace))
ValueError: Duplicate namespace: default
2023-11-13 16:47:39.480780 WARNING AppDaemon: ------------------------------------------------------------
2023-11-13 16:47:39.480943 INFO AppDaemon: Initializing HTTP
2023-11-13 16:47:39.481103 INFO AppDaemon: Using 'ws' for event stream
2023-11-13 16:47:39.482709 INFO AppDaemon: Starting API
2023-11-13 16:47:39.483663 INFO AppDaemon: Starting Admin Interface
2023-11-13 16:47:39.483852 INFO AppDaemon: Starting Dashboards
2023-11-13 16:47:39.488758 INFO HASS: Connected to Home Assistant 2023.11.0
2023-11-13 16:47:39.494672 INFO AppDaemon: App 'mint-scraper-for-home-assistant' added
2023-11-13 16:47:39.495045 INFO AppDaemon: Found 1 active apps
2023-11-13 16:47:39.495134 INFO AppDaemon: Found 0 inactive apps
2023-11-13 16:47:39.495205 INFO AppDaemon: Found 0 global libraries
2023-11-13 16:47:39.495286 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2023-11-13 16:47:39.495878 INFO AppDaemon: Running on port 5050
2023-11-13 16:47:39.508427 INFO HASS: Evaluating startup conditions
2023-11-13 16:47:39.510334 INFO HASS: Startup condition met: hass state=RUNNING
2023-11-13 16:47:39.510464 INFO HASS: All startup conditions met
2023-11-13 16:47:39.548688 INFO AppDaemon: Got initial state from namespace default
2023-11-13 16:47:41.498456 INFO AppDaemon: Scheduler running in realtime
2023-11-13 16:47:41.500103 INFO AppDaemon: Adding /config/appdaemon/apps to module import path
2023-11-13 16:47:41.500311 INFO AppDaemon: Adding /config/appdaemon/apps/mint-scraper-for-homeassistant to module import path
2023-11-13 16:47:41.501974 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/mint-scraper-for-homeassistant/mint_scraper.py
2023-11-13 16:47:41.779498 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/mint-scraper-for-homeassistant/mint_scraper_app.py - ignoring
2023-11-13 16:47:41.780146 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/mint-scraper-for-homeassistant/__init__.py - ignoring
2023-11-13 16:47:41.780531 INFO AppDaemon: Loading app mint-scraper-for-home-assistant using class MintScrapperApp from module mint_scraper
2023-11-13 16:47:41.781077 WARNING AppDaemon: Unable to find class MintScrapperApp in module mint_scraper - 'mint-scraper-for-home-assistant' is not initialized
2023-11-13 16:47:41.781397 WARNING AppDaemon: Unable to find module mint-scraper-for-home-assistant - initialize() skipped
2023-11-13 16:47:41.781682 INFO AppDaemon: App initialization complete
2023-11-13 16:47:48.391091 INFO AppDaemon: New client Admin Client connected
