Hello, new install of home assistant green (November 2023). I plugged in Sky Connect assuming it would be a simple installation. It’s not been smooth at all sadly
At one point during setup, it I wanted to use Thread as well, I said sure why not.
I then tried to actually configure zigbee and it complained about being multiprotocol and created a Repair, after reading various threads I now I’ve restored the default zigbee firmware (I actually don’t care about Thread right now)
Right now I want to simply setup zigbee, so I’m following the steps but not had any luck
Seems you are using the correct port, you could replace /dev/ttyUSB0 with the id (dev/serial/by-id/usb-Nabu_ bla bla), but it probably won’t help. Not using SkyConnect myself, so I don’t know
On the Select a Serial Port step, the correct /dev/ttyUSB0 path was auto selected.
On the Radio Type step I selected, EZSP (which I believe is correct, but it would be great if this simply said SkyConnect)
On the Serial Port settings, I used the full path from hardware info /dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_96b39378b596ed11892dc098a7669f5d-if00-port0
I eventually solved this by going to System → Add Ons → SkyLink experimental and then removing. Tbh as a newish home assistant user I had no idea Add Ons existed. I was then able to reconfigure zigbee as normal.
